I've just bought Samsung XL2370HD and I'm having some problems when connecting it to my PC via a HDMI cable. The connection to the PC is via a DVI-HDMI connector and the other end (HDMI) goes directly into the monitor. When I select the HDMI source, using native 1920x1080 resolution the picture looks over sharpened and it is outside the screen borders (does not fit).
Any other connection setup is fine and these include:
PC > Monitor:
DVI-VGA Adaptor - VGA Cable - Monitor
DVI-HDMI - HDMI Cable - HDMI-DVI - Monitor
But only when I plug the HDMI cable directly into the monitor the picture is not right.
Please advise.
Thank you.
PC > Monitor:
Please advise.
Thank you.
