I have a Dell monitor which has VGA, DVI & Displayport inputs. The DVI works fine using an HDMI->DVI cable from my PC or my (Dell!) laptop.
If I try an HDMI cable with a HDMI->DP adapter I get no joy at all, even if I manually select the DP.
Should this work? Obviously there is nothing wrong with the HDMI->DVI cable, or with the HDMI ports on the laptop or PC.
The adapter came from a well-known company, sadly the Dell monitor will be out of warrantee.
