HDMI Matrix
3 Jan 2003
I want the ability to connect my PS3 to my TV and PC monitor (only 1 screen displaying the image at time)..
may do the same with my PC, so potentially 2 HDMI inputs to 2 HDMI outputs
anyone here used a HDMI Matrix to do the same?
Do you actually need a matrix or not? As in, do you want to be able to send any input to any output? If you can get rid of that requirement and have the PS3 or PC going to both screens and just turn off the screen you aren't using then it becomes a lot cheaper.
I don't need the PS3 or PC to be displayed on both screens at the same time.
1 screen at a time :-)
thinking about it I probably wont display my PC on the TV, So I only really want the ability to display the PS3 on the TV or Monitor
Guess I can do this with a HDMI splitter? so 1 input for the PS3 and 2 outputs for TV and Monitor?
cheers
