- 28 Mar 2005
- Newbury
I'm looking at getting some HDMI over cat5... "adapter things". But need some questions answered.
Much thanks in advance.
- Does it have to be a direct connection for the cat5? I presume being able to run through switches wouldn't work and you need to go HDMI > Adapter > Cat5 Adapter > HDMI? I'd love to be able to do this.
- Presumably there's nothing to degrade the quality with these? I'd have thought all the adapters should produce the same result if they work?
- I've seen some adapters that only require one cat5 cable, and some that take two? Is there a major difference? I've seen examples of both types claiming 1080p.
- Are there any brands to avoid? Should cheap ones be ignored? Or is it like HDMI cables, where as long as it works, the cheaper the better?
