HDMI over Ethernet
11 Jun 2003
Hampshire
I have 5m or so of good quality cat6 terminated at the PC and behind the TV across two rooms. I want to be able to have a game run on a separate monitor (the TV) when the Mrs is using it.
I’ve tried twice in the past to run HDMI over the run, one set stopped working after a while, the other just doesn’t work. The run seems to be working fine; I’ve tried using a tester on the terminal, as well as using my PC on
Can anyone recommend a reliable set that actually works? And perhaps she’d some light as to why the others didn’t.
The sets were cheap jobs off Amazon so perhaps that’s it.
Hi mate, thanks for posting. I have a Steam Link but it mirrors displays.
Cables are already run, I’d just have to plug in the converter at each end.
