- 4 Mar 2006
- Macc
Hi guys,
here's a little conundrum for you all. I've recently received a 24'' Samsung (P2450) screen that was connected to my HD5770 via a dvi cable. I thought, heck with it, if I'm getting a 24'' screen I may as well get a card that will run on max resolution and without hickups - upgraded the 5770 to a 6970.
Now, I haven't tried the dvi cable yet as I went straight for an HDMI one that was with the card, but to my surprise, despite the screen being at max resolution I have bits cut off on all sides of it trimming the display by an inch or so. I am currently updating the drivers to 10.12 to see if that helps anything, but in the mean time - would any of you happen to know what may be causing thins? I cannot run auto adjust on the monitor, I'm being told it is disabled, manually adjusting the size is unavailable as well. In short...halp!
0 was bit overkill, but managed to get the sweet spot
