HDMI problems
21 Dec 2010
Glasgow, Scotland
Hey folks. So I patiently waited all weekend for a mini HDMI male to HDMI female adapter only to find it doesnt fit in my GTX 570 because it hits my case on the way in :(
So im wondering if its possible for a temporary fix to file down the plastic coating around the HDMI adapter? How is it put together inside does anyone happen to know?
Thanks
I've filed down my HDMI-DVI adapter, with no issues. I found it to be almost solid plastic ( guess its mostly plastic to make it feel like more than two connectors and a pcb worth 20p).
Cant see HDMI-HDMI being any different
Sadly I filed it down as much as possible, im now hitting metal but it wont fit :( Im going to need to find a slimmer adapter. Wont be difficult but its just annoying :p
Do you think I should send an email to Corsair about the case not leaving enough room for most adapters and cables? Might get a freebie :p Or at the very least the may suggest an adapter that fits :)
