- 4 Nov 2002
- England - Leeds
Hi there, please can anybody assist me with your expertise, I don't know if I should be posting in the sound forum or the graphics forum as this kind of applies to both.
Basically I've had a setup for years on my current PC that has always worked until recently. My setup is I have a gaming PC that plugs into my AV receiver and my AV receiver plugs into my projector.
For years using windows 7 and using the shortcut Key "Windows-P" to set the display output I have always been able to just select either "EXTEND" or "Computer Only". Anybody who has ever outputted to two displays or had two monitors connecting to one graphics card will know what I mean by this.
Basically the problem has come now that since building my new PC and reinstalling a fresh install of windows 7 onto my SSD. I now find that I have to have the output set to "Duplicate" in order for my AMD graphics card to output the sound to my AV receiver speakers.
If I have the output set to "Computer only" there will be no sound, if I have the output set to "Duplicate" there will be sound but there will be screen tearing on my monitor as its 60hz but before I never had to use duplicate I just always left my computer on "Extend" for years, even if the projector was off I could play games on my PC with one monitor and have sound and no screen tearing and everything was perfect. So this is very annoying.
Basically I need to know if there's some way I can get everything back to how it was before? Can I somehow force my graphics card so output sound when I set my desktop to "Extend" or "Computer only" ?
As of right now if you set the computer to "Computer only" and then go to "Playback devices" in windows the HDMI sound device disappears, only when I choose duplicate will it return.
Thanks in advance for all your help and I hope I've explained this annoying problem ok.
EDIT: I think if I cant resolve this problem because it annoys me so much I might have to buy another sound card that has HDMI slots so I can output the sound that way. I have a separate standalone sound card at the moment that has optical and I plugged that into my AV Receiver but that only outputs 2 channels so that's no good either.
