HDMI splitter, do they work ?
25 Jan 2009
East Kilbride, Scotland
Hi. I have a 980ti that is connected to my monitor with dvi. I also have a tv in my livingroom and bedroom which were both connected to my old 680's via hdmi. The 980ti only has one hdmi and I don't really want to keep switching over the cable when I want to change what to I'm using. Is a hdmi splitter, to have them displaying on both tv's at once the way to go ? Or do they cause lag etc.
Thanks
Only problem with DVI to HDMI is that you won't get the NVidia sound no? Might not be an issue if you have optical audio or another way to get the sound across?
Your right. I ended up ordering a displayport to hdmi connection instead as they transfer audio as well
