Hello
I’m after a graphics card which is capable of playing HDTV play back through a HDTV, gaming is not a priority as only a 7 year old will use the PC for limited gaming at lower resolutions (17” monitor). I’ve got some HD .avi .wmv .mkv files and in the future I’ll either get a Bluray or HD-DVD drive.
I’m so far tempted to go for a Radeon 2400 Pro (Silent 256MB DDR2) but I may spend a bit more a get a one of the 2600 range, would one of these cards be OK?
Also I remember reading a while ago about problems around outputting a HD signal to a HDTV has the HDCP standard corrected those issues?
Sorry if these are daft questions!
The PC the card will go in:
C2D 6300
ConRoe945G-DVI
2GB 677MHz Ram
Vista 64
C2D 6300
ConRoe945G-DVI
2GB 677MHz Ram
Vista 64
