HDTV TV Card
15 Jan 2005
Towcester
Hi all,
Planning to build a media centre pc, but as our new tv is going to be HDTV compatible, want to have a HDTV tv card, with dual tuners preferably
Only one I can find which fits the criteria is the Fusion HDTV DVB-T card, has anybody got any experience with this?
Could always get two single tuner cards, but ideally want to get a dual tuner for neatness and ease of use.
Most digital cards support hdtv or at least claim to, after all all they do is recieve a signal, they dont need to transcode it. Though remember that the cards out now probably only support mpeg2 hdtv and not mpeg4 which is what the uk will use, the card you mention only supports mpeg2 so it wont work with uk hdtv.
