Head Exploded with Port Forwarding
28 Sep 2008
Britain
Ok, this is the situation.
I have two servers behind a router / firewall that I need to access on port 443.
Now, with the crappy standard BT HomeHub, I was able to do this by accessing on a different port, and then the router / firewall would translate that to 443 and forward on to the relevant server.
ie:
external 80.80.80.80:443 would go to internal 192.168.2.110:443
external 80.80.80.80:444 would go to internal 192.168.2.100:443
Now, we have "upgraded" (in quotes, because it doesn't feel like an upgrade) to a Netgear DGN2200v3 with the latest firmware and the option of "translates to" doesn't seem to exist.
With changing the listening port of the application on the 192.168.2.100 server, is there not a way around this?
Thanks
Have I got the terminology right? I was sure it was called port translation, or, translates to, in the homehub
I don't really want to stick one of the boxes in the DMZ.
The names vary, but it would be called something like that.
My Vigor2920 calls it 'Port Redirection'. A BT Business Hub I have access to refers to it as port translation.
The Netgear supports NAT as you would expect, but will not translate the source port to a different destination port.
Netgear equipment sucks. Period.
I have a DGN2200 in use....with EVERYTHING disabled in the capacity of a Wireless AP only....and it even sucks at that.
Return the Netgear, it is a substandard product.
