Yes you guessed it
its a rover engine lol
Bought a 4 year old MG TF in the summer for cheap with 20k miles on the clock. Thought i better get a warrenty with warrenty direct due to the repatation of these cars...
Had a big service in august cam belt changed no probs, oil changed etc.
MOT last month no probs....
Checked my oil maybe 2-3 weeks ago no probs...
Checked my oil yesterday and its basically on minimum now with slight mayo on the dip stick, not a large amount but there is some on there.
Checked my coolant water and its looks all yellowy and thick, i had to drive 50miles home from my girlfriends uni and topped up the coolant water and when i checked the coolant water this morning it has dropped a good 5cm since i put it in yesterday so it looks like its loosing coolant water aswell!
Does this sound like a Head gasket failure?
Just phoned the claims dept for warrenty direct but its closed untill monday now and i need my car for work! Do i get the work done asap and then phone them first?
Cheers guys
Cheers guys
