Head Scratcher.....what PSU for 4890 Crossfire?
10 Dec 2004
Oxfordshire
as per the title, anyone give me a good budget (but not cheapo) PSU that would be up to the task
What sort of area should i be looking at? 650w ish?
rest of the system is an E2160 @ 3ghz (maybe an E8400 soon)
4GB DDR2
3 120mm fans
SATA PCI Card
4xHDD's
4-5 USB Devices.
Cheers
Ben
550w would do it, but to be safe I would go for a good brand (corsair) 620-650 :)
Generally, peoples perceptions of what is required are over specified.
I ran 2x4890s on a Sparkle Epsilon 650w PSU, Had to upgrade to a 850w as the pc would shut down when under pressure.
Antec TruePower New Modular 650W is probably the cheapest decent PSU that would have enough PCIE connectors for 4890 crossfire. You might want to go for a 750W supply though just to make sure it's not running too close to its limit under stress.
The Corsair website seems to say the TX 650W also only has 2 PCIE connectors. The Antec I suggested does have 4 but it's currently out of stock.
As for Chieftec, can't say I've had any personal experience with them but I've had a quick look for reviews and they seem better than most of the other budget manufacturers, but I'm not sure I'd trust my PC with them.
I think you would be flying kinda close to the wind with a 650w, as I said, I had a great 650 psu that just couldn't manage under the pressure of 2x4890 when they were both flat out.
Think about future upgrades too, is 650 enough? Sorry to go on but I don't want to see you disapointed.
no no thats fair play mate :)....i have decided its most likely going to be that £80 750w Chieftec as its been getting some great reviews, if something comes up close to that price of that then i will go for it, but £80 is going to be my ceiling
Its good to get advice from someone who has been in the situation so cheers :)
