Head unit recommendation
Caporegime
1 Nov 2003
Lisbon, Portugal
Hi all,
Looking for a head unit for the gf's car.
I want a DAB radio with antenna included and aux in on the front to connect her phone up.
Budget wise, £50-£100?
Single din only :)
TIA
Jake
I've got a Sony unit that I bought from Halfords for about £100 2-3 years ago, it's been superseded by a newer model so can't recommend that one from personal experience but it does appear to get good reviews - Sonys tend to be consistent enough. Check that it comes with an internal DAB aerial (mine did but I recommend you fit an external one no matter what HU you get).
Newer unit:
http://www.halfords.com/webapp/wcs/...uctId_918359_langId_-1_categoryId_165655#tab1
Thanks guys, I found the Sony above on caraudiodirect.co.uk for £99 with a windscreen antenna which is £19 on its own, so have ordered that one :)
