The n/s headlight cluster has gone opaque, is this likely to be due to moisture with the seals probably naff? The o/s headlight is as clear as it was 10 years ago (Mk1 Focus 99 reg.)
If it is, is it better to remove, try and clean, seal and replace or spend £20-25 on a decent sealed cluster on the bay and do as straight swap?
Ta
![lightsl.jpg](http://img208.imageshack.us/img208/2329/lightsl.jpg)
Ta
