Headphone recommendations
6 Dec 2002
Stafford
Hi all
I'm after some wireless over-ear headphones. For general use such as at work / walking the dog etc. Budget is about £150 - £180ish. A bit over wouldn't be a big deal.
Any recommendations appreciated
Closed or open back? With or without noise cancelling?
If you own a pair of wired headphones, suitable for outdoor use, maybe consider a BT adapter like a Fiio BTR3/5. You'll save money and they may even sound better than many of the BT over ear headphones where most of the money is put in to the noise cancelling tech.
Really impressed by these headphones. They’re not the latest model from Sony, but the sound quality is excellent as is the noise cancelling ability. Highly recommended.
They are the ones I would be recommending as well. Not as expensive now as they were have been replaced by the XM4 but the quality is outstanding. Tested them against the opposition and they were by far my favourite. Could be worth checking them out.
