Ok, so i need to let her know and its a matter of deciding what to go for then!
Now and then some bose quiet comfort also
Appear in MM
Got my stepson a pair from mm
Think I paid just over 100 for those
He's a railway guard pretty noisy environment
He loves them
Most of these headsets can last most of a day
On a single charge
And usually have a fast charge feature lot use usb-c
10 minutes charge gives you a good length of time
So you're not constantly having to charge them
My Sony lasted 17 hour flight to Australia
Though I may have taken them off now and again
Edit
Anker soundcore q35 quick look found some for 75
Q45 quick look found some at 95
The q35 I paid a bit less
But I still think for the money
They are very decent
Don't sound awful and think there might be
An equaliser app
The ANC works pretty well too
Build quality seemed good too
Made it to Australia and back nothing went wrong
no bits falling off or cracks in plastic parts etc
Yes my Sony might be better but given they cost 4x as much
Are they 4 x better no
