Headphones for gym/running ?
24 Jan 2008
Londinuim
Hi.
I thought that it's better to ask here than in sound city section...
Looking for decend headphones for gym/running.
I assume that in ear ones would be best ?
Maybe also wireless ?
I appreciate all suggestions.
Thanks !!
I have some plantronics bluetooth one - they kinda go round the back of your neck and over your ears. Stay put and don't get in the way. Sound pretty damn good too.
Plantronics BackBeat Fit, they be.
Personally use JVC HAFX1X, quite bassy for earphones which is perfect for that filthy music we all have on our gym playlists ;)
Best part is that I've had them for 4 years now so proving to be very hard wearing and I've snagged them plenty in the gym and don't fall out of my ears but that of course all depends on the fit.
Tend to be around £10 to £14 so good value although I've recently bought the new version (Xtreme Xplosives) which was completely pants, wires are way to thin and died after a few snags so went into the bin after 2 weeks.
IF you end up with in ear ones you might want to think about also getting replacement tips for them, i find that the silicone ones get too slippy with sweat when running. I switched mine out with some memory foam ones for that reason.
