Heads up: EVGA Bios update for 8800GT SC
3 Nov 2004
UK
Link
http://www.evga.com/support/drivers/
The following drivers/files are available for your hardware and operating system combination.
Note: If you are having difficulties downloading the driver file, please make sure you completely disable any third party download managers.
Bios Version : 62.92.16.00.22
BIOS Date : 11/30/2007
Bios File : N802 Update 1.0.zip (FTP / HTTP)
Notes :
EVGA 8800GT Superclocked BIOS Update
This updated BIOS is only for the EVGA 8800GT SC (512-P3-N802-__)
KO and SSC versions will be posted soon
Updates are as follows:
* Improves fanspeed auto sensor
Windows XP/Vista Flash Instructions
* Download the appropriate update above, and extract files to a location on disk
* Completely remove NVIDIA display driver from Add/Remove programs
* Restart PC
* Make sure no programs are running in the background, and double click update.exe from the extracted .zip file
* Press “Y” to begin flash
* After flash restart PC
* Reinstall the 169.09/169.12 or later graphics driver
* IMPORTANT: If running in SLI, each card needs to be flashed separately
As said where, nobody mentioned it before in this thread.
Probably will work but I would rather use proper bios incase their cards cant handle speed or Timings, there is nothing that great about the update is there.
I was referring to the potential ID mismatch.
I've flash against the ID many times, no big deal.
Thousands of bios here. http://www.mvktech.net/
I know the site and how to flash TY. ;)
Just looked like you meant it had been said in thread already.
They also advise you to not flash unless you have a back up card like an old PCI card or a Blind Flash Floppy made up (I have both).
I'm sure you do, I wasn't posting info just for you. :p Often times EVGA release a bios long before the others, if the others ever update. As you say make a blind flash disk if you don't have a PCI graphics to hand.
I thought people are having troubles with the stock fan speeds getting stuck at 29%?
