Headset for xbox 1s
30 Oct 2013
Anyone recommend a good cheap headset that plugs into the controller.
Mainly play cod and fps.
Would in ear be better option?
Dont like on ear but around ear or in ear is fine.
Looked at the Sades headsets for about £20 and they seem to have good reviews.
Turtle beach any good?
If you can live with poor audio by all means get a cheap plug in headset; it won't be loud as theres simply not enough mW output to power the headphones. At the price range they'll all be much of a muchness.
I'm pretty sure that that mobile phone IEM's with the inline mic work - I'd try that and save some pennies tbh!
EDIT:
https://www.polygon.com/2016/2/28/1...le-earpod-earbud-headphones-buzzing-noise-fix Apple Earbud's work with a slight tinker. Should be the same principle for others.
Shawrey
At the moment I'm using the buds that came with my Galaxy S7 but they're not that great tbh.
I think I'm going to try and find a decent set of earbuds with mic.
Recommendations welcome!
Im using the cheap Tritton Kama headset, it is on ear but really comfortable. And sound and mic are really good! I mean for sub £20 you cant go wrong on this imo.
