Having just picked up GTA V yesterday for the 360 I'm now looking to grab a headset of some sort to use when playing it. But I'm not sure what to buy. I don't want to spend an absolute fortune so something inexpensive at the lower end of the market is preferable. Around the £20-£35 area. Having Googled headsets it appears that most of the ones designed primarily with PC's in mind won't work on the 360?
Also, I'm not sure whether to try a wireless pair or a wired set. The issue with a wired set is the setup I've got in our living room, the Xbox and TV are at one side and the sofas are about 5 meters away on the other side of the room so cable length would be an issue. Hence looking at wireless kit. Or would it be possible to get an extension lead of some sort to use a wired set with? If so what sort of cable, a USB extension lead? I'm not totally sure where a wired headset connects on a 360, is it the USB ports or elsewhere? I'm also thinking a headset with a mic built in would be handy in case I decided to get into GTA:O at some point.
Apologies for the wall of questions, any advice appreciated. Ta.
