Headunit with rear USB?
18 Oct 2002
UK
I'm looking to buy a fairly budget Headunit, but would like one with a rear USB so I can plug in an SD Card in a dongle and use it that way, don't want a USB cable trailing out the front of the dash all the time really. And the units with SD card slots in the front are all a bit pap/pricey unless someone can recommend a decent one here?
Chers!
My Pioneer is just that, £100 too and looks sleek, the USB stick sits in the glovebox as if it were made for it!
Not found it fiddly at all, it's nothing like Kenwood knobs for example.
Tactile feedback and pretty solid/stiff in movement.
