I have placed this in the laptop section, but if it is more suited to the motherboard or graphics card section then, admins, please move it.
I have/had an asus g1s laptop, that was amazing to use and play games on. I bought it in a Best Buy in Las Vegas, so taking it back was not an option. It was also just over 2.5 years old. The problem was the dreaded nVidia problem, where the chip over heated. It did this since I got it, and unfortunately as it was my first laptop, I didn't realise there was a problem.
I have tried to have it fixed by heat soldering the chip back on, to see if that works, but the company that 'tried' were unsuccessful. When I say 'tried', I mean the looked inside and said "lets just leave this alone and go for lunch instead...eh?!"
That was the background to the story, here's the question:
Does anyone know what temp i should apply to the chip to 'reseat' the pins? Im going to try and do it myself, as I can't break it any worse than it already is. Its currently a write off, so anything short of setting it on fire will be an advantage. I was told that you can apply lots of heat to bend it back into shape and reseat the pins, as that is a major problem with the chips.
Has anyone tried this, or even better, been successful doing it?
Any help with this, or a point in the right direction is greatly appreciated.
Thanks all,
atocp
Thanks all,
atocp
) put your whole laptop in the oven.
