Hey guys,
Im curious as to how you are all keeping the house warm in winter and cold in summer.
I appreciate that this question may come across a bit obvious what with central heating for the winter and typically opening a window for the summer but what other methods are you all using to aid in these times?
During the lovely two weeks of hot weather we have had its been over 32 degrees C in our house and I simply cannot get the heat out. Then it gets to winter and we have to have the heating on almost all the time. We have insulation in the attic (just a small amount of fibre glass, about 4-6 inches of the stuff) but some of it is being covered by some boards I put down so we could use it as storage. Does this affect the efficiency of the insulation?
Cheers!
Cheers!
