heat paste
13 Jan 2006
Wigan
jus want to no if this is the best heat paste
MX-1 Thermal Compound
i ordered an Accelero X1 and want to check if this the best stuff
also any1 got an accelero does it come with pre applied stuff? an do u no if it come off easy?
thx
joker
xx
thx
joker
xx
The MX-1 paste is indeed supposed to be good, from what ive read on here even better than AS5 apparantly.
A Random Name
xxx
MX-1 is good stuff. I normally use AS5, but I doubt there would even be 1degree difference between them. Not sure if the accelero comes with stuff preapplied. I would have thought it would come with a small tube of generic stuff.
