Im experiencing a bit of a heat problem with my Aopen XC cube SFF.
Its got a 3ghz P4 prescott running at 3.6ghz, and the temps are hitting 70 degrees on full load
, and around 58 idle.
Im thinking about changing the HSF+AS5, an maybe putting active cooling the the chipset. Would this make a lot of difference, or should I just be happy with the current temps?
, and around 58 idle. Im thinking about changing the HSF+AS5, an maybe putting active cooling the the chipset. Would this make a lot of difference, or should I just be happy with the current temps?
