I'm after some more advice on cooling, a solution for my graphics cards. I don't know if its because the central heating is on a bit more now or not but last couple weeks I've seen increase in my GPU load temperatures.
Just finished playing COD4 and theyve peaked at 93dg, average over over 90.
I have Riva setup to whack the fans at 100% at those temps, I also have an exhause fan under each graphics card as you can see in photo.
2x 80mm fans at front of case
1x 80mm fan at side
1x 120mm fan on back
Any ideas on what I can do, without replacing the stock coolers on the cards?
The cards are overclocked but only slightly.
1x 80mm fan at side
