- 7 May 2006
Hi all
I'm thinking of getting this heat sink
http://www.overclockers.co.uk/showproduct.php?prodid=HS-056-TR
But I'm wondering if the following backet will fit with this heat sink.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-058-TR&groupid=701&catid=57&subcat=821
I know that it will fit with the following heat sink
http://www.overclockers.co.uk/showproduct.php?prodid=HS-027-TR&groupid=701&catid=57&subcat=821
but I would like to go with my first option the True Black CPU Cooler.
Thanks
Thanks
