Heated Grips - Advice Please
I've always fitted the Oxford heated grips to all my bikes.
They have 4 settings, 100% being extremely hot even through winter gloves.
Unlike some of the cheaper brands the Oxford sets come with all kinds of fittings, mounting plate, spacers etc.
I've also used the Oxford ones when bike specific ones from the manufacturer aren't available. They've always been good.
The last ones I had from Oxford had a dial to control the temperature. Hottest setting was actually too hot to hold with summer gloves.
One thing I will say though, know your bike's electrical system before you try to fit them. You will need to install a relay (comes with the grips) and then find an ignition switched +12 line.
I've had the Oxford ones at £50-£60 and the Dr. Bike ones from J&S at £25. No difference at all. OEM is best, but can cost a fortune.
They are invaluable in colder weather, it's not a wussy thing to fit.
