Heating Houses with Nerd Power
17 Mar 2009
Scotland
I saw this story via the bbc about how some data centres are placing units in peoples homes which help heat their homes in the process.
What with doing a fair bit of Folding over the years I can certainly say its kept my house warmer :)
Do any of you have weird and wonderful setups that aid heating your homes?
http://www.bbc.com/news/magazine-32816775
My rig is in a tiny study thats had the radiator off since it was installed, i want that room warmed i just fire up bf4 for half an hour and let the 290x do the heating.
Can get intolerable though over long periods, and the desk is so large i cant reach the window.
I do the same, it only consumes 150W but it is enough to heat the room after a few hours.
If they threw in an unused portion of their data link then this would be a fantastic idea.
The server in the radiator does not stop working when the unit is turned off, but the heat is pushed into an extractor on the outside wall. And in the unlikely event that a user needs heat but the internet is down and the radiator has nothing to work on, it starts performing dummy equations.
With data centres estimated to account for 1.5% of global electricity consumption (in 2010), this wastage is costly to businesses and to the environment too.
sounds rather eco friendly....
doubt your electric companies would let you stay on a commercial contract either?
feds probably be raiding from the heat in the winter lol
If they made a model that attached to a bed so your wife could put her cold feet on it, then the supercooling effect would let them overclock it to 5-6Ghz easily.
When I was mining with 6 gpus my house was like a furnace even while it was snowing outside.
I actually posted my energy usage graphs comparing year on year gas and electric usage for anyone interested.
http://forums.overclockers.co.uk/showpost.php?p=27405382&postcount=39
The noise was really bad though. Data centre equipment isn't exactly known for being quiet either so I'd want to know how that was being dealt with before signing up.
I see how this concept could be used.
In a city like New York, you could have the water fed into a huge watercooled data centre (I know there are other implications due to the water, NSA ;), etc.., but i'll keep it simple). The water fed in is warmed as the servers are cooled, which then can be fed into the hot water system.
If the water is 30c warmer before being put into the heating system, then you save the energy required to heat by that 30c increase, (which when being kept simple is water in->water out with the data centre being put in series) and water requires 4.2kJ/litre to raise it by one degree. If 1000 litres are used in a day, you are saving 126MJ of energy, or 35kW/h.
Just a thought. ;)
Mine bitcoin and you can get warmer even cheaper.
Did you not look at my energy graphs? You would pay through the nose to mine bitcoin or any other altcoin, ASIC or not. It's not profitable to mine anymore (on most hardware) so the electric usage would just end up costing you more than the setup cost of one of these radiators.
I'm assuming the company absorbs the electricity cost for this scheme?
I know some big companies are 'reclaiming heat' from the server room to heat the offices when they have a server room in the same building, actually it might even be google doing this.
It does make sense because this heat reclamation thing is being pushed for houses too because it's more eco friendly and economical etc.
My pc is also pretty much all the heating I need in my office too :)
edit: nope it was amazon...
http://www.greenbuildingadvisor.com/blogs/dept/building-science/using-server-farms-heat-buildings
