- 8 Jan 2004
Any heating experts in here?
I have a problem with my linea vokera 28 combi boiler losing pressure. For a while the pressure would shoot up when heating, then die to zero when heating switched off. The hot water would also cycle hot to cold when in the shower. I have cover with the aa and they came out and changed the expansion vessel and pressure relief valve. This solved the issue of the rise in pressure and the hot to cold fluctuation, but the pressure drop still happens. I can top it up to 1.5 bar and it holds there nicely for a long time, including having showers. It holds fine when the heating is on, but after I switch the heating off the pressure drops to almost zero over approx half an hour. Aa came back out and changed the pressure relief valve again ( some water leaking from outside pipe) and changed another part - a sort of barrel shaped brass component. However he left before he could see that the problem was still there.
Can anyone offer any advice before I get the aa out again and waste another half day off work?
I have checked all radiator fittings and no obvious leaks. Left tissue paper at all fittings overnight and all were dry in the morning.
Worst case scenario is a leak in the pipe under the kitchen floor as we have just spent a fortune on karndean flooring. I'm willing to change the boiler as long as I know that won't be a couple of thousand wasted.
Help?
Help?
