Heatkiller Res + EK pump?
27 Jun 2020
New Zealand
I'm planning a new build, can the Heatkiller 200 D5 accept any D5 pump? Such as this Quantum Inertia from EK? It looks like it has a weird shape and wouldn't integrate into the res lol...
The Heatkillers are not sold in New Zealand so I will have to order it from overseas. I want to buy mostly NZ in case of warranty issues, so don't want to buy an offshore pump as well...
That D5 you linked too is the D5 with a pump top on it. So basically allows fittings to be connected to it. You mention integrate so I assume based on that and prior post, the hestkiller res your looking at, the D5 would integrate directly into the res. In which case you want just the D5 pump. Like this https://www.ekwb.com/shop/ek-d5-pwm-g2-motor-12v-dc-pump-motor-sleeved
Now that link you provided will have the D5 in it of course once you strip it out, but you would basically be overpaying for the pump top which you would not use.
