- 4 Aug 2007
- Wilds of suffolk
Just been thinking about heatpipes and the technology.
I didn't really understand that well how they worked so did a bit of basic research and found that they work as I thought. A small amount of a liquid is stored within a metal tube.
The heat of the processor turns this liquid to vapour which then travels along the tube to the main part of the sink where due to the airflow it cools and condenses.
Ok pretty simple stuff.
But the basics just strike me that mavity is surely going to help this situation dramatically no matter what clever strategy has been applied to getting the vapour to travel along the tube.
One scarey bit I found. If you generate an amount of heat that exceeds the amount the pipes can handle they basically stop working as all the liquid can be vapour cooling down. That would mean you would be relying on the passive cooling effect of the big sink rather than the pipes themselves.
So have I got it wrong, or should I be turning my tower onto its side during warmer weather?
