- 11 Apr 2010
Hi all,
My motherboard is the Asus P5Q deluxe (775) which has pipes around the processor, and its quite chunky.
I am thinking of getting the Corsair A50 from ocuk however I don't know if it will fit? The heatsink is 775 compatible but I had problems fitting in a Gigabyte X power, which was 775 too, and could only get the fan fit in a certain way.
What I wanted to ask is does it impact the board if the heatsink is not pointing the correct way? is there a correct way where it should be facing? If it takes me longer than 20 minutes to put this in, I am doing something wrong, right?
Appreciate any advice! Many thanks.
(still haven't decided though but it will be one of the two for sure)
