My heatsink is the Titan Amanda TEC cooler and when i boot up the pc i get a terrible scretching noise which i think is the TEC alarm.
The alarm should go off when cpu is under 15c or over 75c
ive checked in bios and cpu temp is 14c and system temp is 8c,the alarm lasts for about 1-2 mintues until the cpu temp is16c, idel temp is 26c load temp about 30-40c so my question is,
what kind of problem can this cause because i always thought the colder the better.
if my heatsink is playing up could anyone recommend a good heatink
motherboard msi p45 platinum
cpu intel quadcore Q9450 2.66ghz
Thanks.
Thanks.
