Hi all,
I'm building a mATX 5820k system inside the Fractal Design Define Mini case with NH-D14 cooler as it is probably the best cooler within 160mm height however I would like to replace the Noctua fans with black PWM fans to match the colour of the build and replace the case fans with better ones. I have a budget of £60 max for these fans.
The Define Mini case has these fan mount points but I'm not sure if I need a fan on the top and side panel as well as correct me if I set exhaust or intake fans wrong below:
1x 120mm rear (exhaust)
2x 120mm front (intake)
1x 120mm bottom (intake)
1x 120/140mm top (?)
1x 120/140mm side panel (?)
