Hello!
Putting together my first build. Got some airflow queries.
Excuse the lack of cable management etc... not finished yet!
Basically my heatsink, be quiet! shadow rock 2 is rather large and fits really snug inside my case. The heatsink fits fine however the fan doesn't. Well in certain places.
It was originally attached to the left hand side, sitting just above the RAM. This was fine however it meant the fan hung over the side of the case just enough to disrupt the panel meaning it won't fit.
The fan fits in the bottom just fine as currently I have no gnu or anything to get in the way. But will this cause a problem with the psu and airflow?
Haven't done anything taxing with the pc but it runs nice and cool.
What would you reccomend? Should I rearrange some of the case fans and move the hearsink fan to the top or right hand side?
Hope this made sense...
either get a new cooler or try to move the fan upwards using the fan mounts.
