- 8 Jul 2010
- Staffordshire
I'm currently building my first PC, following the tutorial in the hardware section of the forum where I can. The tutorial doesn't have a section for an AMD build yet though so I just have a question in regards to the best position for my heatsink.
I'm using an Antec 300 which has a fan at the back (as usual) and a fan at the top of the case. I'm using rather tall RAM, the RAM heatsinks block a couple of centimetres of the heatsink fan when the fan is installed so that it pushes air from the front of the case, through to heatsink fins and out through the rear case fan. If I install the heatsink with the fan pushing the air up and out through the top case fan, it's airflow is unimpeded but the heatsink fan is above the PSU fan.
In which direction should I have the heatsink and it's fan pointing?
