- 14 Mar 2012
I've got:
p8z68-v-lx
2700k
16gb vengence (4x4gb blue with tall heatsinks)
palit 560 ti gfx
I've found the cpu at 4Ghz hits 74c with the stock intel heatsink+fan.
I want to get 2700k between 4.7ghz to 5ghz, so I've read I need Noctua dh14?
But the tall vengence ram will be physically in the way.
So questions:
recommended solution?
1. If I swap the ram for low profile do I loose anything without the heatsinks?
2. If I change mobo instead which is the best motherboard for this combo?
(and supports sli)
3. Alternatively is there another heatsink+fan that does as gooder job as Nocura dh14 for 5ghz and will fit the p8z68-v-lx + highprofile ram?
Thanks in advance
p8z68-v-lx
2700k
palit 560 ti gfx
So questions:
(and supports sli)
Thanks in advance
