19 Sep 2015 at 21:17 #1 Shenton Shenton Associate Joined 15 Sep 2015 Posts 32 hi ive just purchased a Gigabyte GA-Z170X-UD3 Intel Z170 (Socket 1151) DDR4 ATX Motherboard does the heatsink need to be socket 1151 as i cant find any on the website. what heatsink would you recommend at around £50 price range thanks
19 Sep 2015 at 21:18 #2 pepp77 pepp77 Soldato Joined 13 Oct 2008 Posts 5,236 Location SE London Born and Bred Any 1150, 1155 or 1156 Cooler will fit as they all have the same size fitting.
19 Sep 2015 at 21:21 #3 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 thank you what would you recommend around the £50 price?
19 Sep 2015 at 21:21 #4 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent What case will you be using as you need to check the size.
19 Sep 2015 at 21:22 #5 pepp77 pepp77 Soldato Joined 13 Oct 2008 Posts 5,236 Location SE London Born and Bred What CPU? Planning to overclock? Air or Water? What case?
19 Sep 2015 at 21:27 #6 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 case: https://www.overclockers.co.uk/showproduct.php?prodid=CA-075-XG&groupid=2362&catid=2277 its a intel core i5-6600k lga1151 not planning to overclock and possibly water just depends on price
19 Sep 2015 at 21:48 #7 Danny75 Danny75 Soldato Joined 26 Aug 2013 Posts 8,394 YOUR BASKET 1 x Prolimatech Megahalems Rev C CPU Cooler £42.98 And add a 120/140mm fan. The heatsink comes in all black, black/blue and black/red versions (all £10 more expensive).
19 Sep 2015 at 21:53 #8 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 so need to buy a fan seperate? would something like this fit my case? https://www.overclockers.co.uk/showproduct.php?prodid=HS-016-RT&groupid=701&catid=2330 Last edited: 19 Sep 2015
19 Sep 2015 at 22:01 #9 PieEater PieEater Soldato Joined 18 Oct 2002 Posts 4,250 Location Devon My suggestion would be a Thermalright True Spirit 140 which you can get for £38.58 + £4.57 delivery.
19 Sep 2015 at 22:08 #10 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 have you got a link to the thermalright cant find it
19 Sep 2015 at 22:25 #11 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 i really like the water one that i posted but not sure if it will fit my case
19 Sep 2015 at 22:30 #12 PieEater PieEater Soldato Joined 18 Oct 2002 Posts 4,250 Location Devon Shenton said: have you got a link to the thermalright cant find it Click to expand... No as it's from a competitor but it's not hard to find using Google.
19 Sep 2015 at 22:32 #13 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 ok will take a look
19 Sep 2015 at 22:40 #14 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 thanks for the help found one with red leds on it so going to get that till i decide to upgrade to water cooled
19 Sep 2015 at 22:50 #15 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent if its this one (link below) it will not fit in your case: http://www.thermalright.com/html/products/cpu_cooler/true_spirit_140.html?panel=1 Height 170mm Your case height: 160mm height support for cpu cooler: http://www.xigmatek.com/product.php?productid=184&type=specification have a look at this: YOUR BASKET 1 x Alpenföhn Matterhorn Pure Edition CPU Cooler £29.99 Total : £35.96 (includes shipping : £4.98 Ex.VAT).
20 Sep 2015 at 00:22 #16 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 Thanks ive decided to get this one https://www.overclockers.co.uk/showproduct.php?prodid=HS-002-EA&groupid=701&catid=2330 but that matterhorn looks good and is cheaper i just like the lights on this one Last edited: 20 Sep 2015
20 Sep 2015 at 20:52 #17 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Might be too late, but still too big: http://www.evga.com/products/pdf/100-FS-C201-KR.pdf
21 Sep 2015 at 09:40 #18 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 what the one ive ordered or the one you just posted?
22 Sep 2015 at 03:04 #19 Danny75 Danny75 Soldato Joined 26 Aug 2013 Posts 8,394 Shenton said: what the one ive ordered or the one you just posted? Click to expand... They are one and the same. 100-FS-C201-KR.
26 Sep 2015 at 18:44 #20 Shenton Shenton Associate OP Joined 15 Sep 2015 Posts 32 the one i ordered fits with a few mm spare looks good though
