Heatsink Question.
25 Dec 2009
Hi,
How easy is it to remove the heatsink from the following RAM?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-060-GS&groupid=701&catid=8&subcat=
I brought a Motherboard, Processor and the above RAM as a package deal and also brought a Artic Cooling Freezer 13 CPU Cooler.
When I went to install the RAM into the slot closest to the CPU, I noticed that the RAM doesn't fit, due to the bottom of the fan/fins being to close to the RAM Slots.
So was thinking if I removed the heatsink I can still use the first RAM Slot.
Thanks.
Run a thin razor or pry between the tops of the chips and the heatsinks. Do not pry between the heatsink and circuit board or the chips may rip off. Heat from a hair dryer can help.
Does this Ripjaws PC17000 (2133 MHz) use overclocked 1333MHz Hynix H5TQ2G83BFR-H9C chips?
http://aphnetworks.com/reviews/g_skill_ripjaws_x_f3_17000cl9d_8gbxld_2x4gb/2
