- 1 Dec 2009
- Staffordshire
hi
i want to install a corsair A50 cooler on this motherboard
http://www.overclockers.co.uk/showproduct.php?prodid=MB-576-AS&groupid=701&catid=1903&subcat=2046
with the fan facing the front towards the memory
the ram i will be using is G.Skill 16GB DDR3 2400MHz TridentX its a 2 peice kit (cant link because of competitor rules) and i have the feeling it will not fit, would it be possible if the ram was in the 2nd and 4th slot going from left to right?
thanks
thanks
