heatsink suggestions
29 Aug 2010
Bedfordshire
Hi,
just about to do my build, but i need some suggestions on cooling, components im using are below. i am really struggling to decide. i dont want to do a custom water cooled system, i dont want to blow the bank either, £80 is my budget.
i only want to play around with over clocking, i will not be doing anything extreme, but the system will run cooler and quieter with overkill cpu cooling, so i feel it is worth splashing out anyway.
i like the idea of H50 or H70, not sure what is best, and i see i have limited my coice of air coolers with the corsair dominator ram.
so what do you guys think?
I7 950
ASUS P6X58D-E
PALIT GTX460 1GB sonic platinum
Corsair Dominator 6GB CMP6GX3M3A1600C8
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB
Corsair 850AX
Corsair 600T
2 X BenQ G2420HD 24
Samsung SATA Blue Ray SH-B083L/RSBP
love the H50, have it on my main pc and just installed it in an htpc - coupled with an apache black fan it's so damn quiet!
what is the standard corsair fan like?
and the H70 looks a little nicer, pump is nice and compact, looks higher quality, and has rotaing fixings on the pipe work, comes with two fans as standard, i can imagine i will end up buying another fan for the H50, so might be worth going straight for the H70
