well i had to heat sinks stuck to mine 2900 ram and i switched to 8800gts and they not hold anymore what glue you can sue to stick them on ? maybe even some house material glue? or i have to nuy that special active silver ram sink glue ?
use some isopropyl alcohol and coffee filters to clean off the old stuff then buy some of this:
http://www.overclockers.co.uk/showproduct.php?prodid=TH-001-AK
Seems the reviewer used this on his cpu and it worked well! Anyone else ever tried this?
ermm I would disregard that review. lol!
Also, cleans off with some isopropyl alcohol.ermm I would disregard that review. lol!
You've tried it then?
He doesn't say that he used it on his CPU...
For all we know, that could be his graphics cards temperatures![]()
So if it works on a gpu, why shouldn't it work on a cpu?
