Heaven 3.0 benchmark
16 Mar 2012
Hove
Hi,
I'd like to run heaven benchmark 3.0 to test all is ok with my graphics card, what specific settings should I pick and what score (or output) should I expect?
Never run it before soo... Also should I disconnect extra screens?
And should I worry if parts of it aren't fluid? Running it on default settings right now, most is ok some bits are slightly laggy I guess.
Do I need to hit the benchmark button for it to output results? Seems to be on loop ATM
Thanks
1920x1080 X4, X4 at stock settings maybe 1900 ;D
It's just a benchmark mate it doesn't feel the best because vertical sync isn't on obviously to get the highest frame rate.
Press F9
if you want something to compare it too, use the same settings than in the main benchmark thread and see if you hit around the middle of the results for your card.
