Heaven Benchmark Artifacts
22 May 2007
UK
When I run the Heaven benchmark I get these little artifacts at the same point each run, they occur when running at stock and also when overclocked.
Does anyone else notice these too
Here is what it looks like at stock (look at top left)
and here when its overclocked (again top left)
Mine bugs out at the same spot.
Wouldn't worry about it.
Heaven is a pretty buggy application and unless it crashes, again, I wouldn't worry about it.
Never seen that on my 680's unless I have the memory too high but if it is a recurrence in the same spot, I wouldn't worry either.
Its only on the screen for a split second, I only managed to capture it by taking a video on my iPhone and then playing it back on my PC and freeze framing it on the exact moment it was onscreen then taking another screen shot and then uploading to imageshack.
Maybe its an AMD thing if it doesn't happen with your 680s???
Or maybe I just missed it. Nothing to worry about Nle :)
Yeah didn't think it was much to worry about but because its so easy to capture this sort of thing these days thought I would put up a thread about it, which probably makes it seem a lot worse.
It literally flickers on screen for a split second at that point in every round and is probably something to do with the wings going off screen as has been pointed out.
At nowhere else do you see such oddities and it happens even at stock speeds.
