Heavy Duty LP4 splitters/extensions
5 Mar 2014
All,
I have a PSU with no PCIe connectors and I'm im trying to use an Asus R9 290x GPU which requires a 6 way and an 8 way connection.
The PCIe 6 way cable that I have has two LP4 inputs going to one PCIe 6 way.
The PCIe 8 way cable that I have has two LP4 inputs going to one PCIe 8 way.
Therefore I need 4 available LP4 conenctors to join up the required PCIe cables.
I bought 2 LP4 splitters (one male to two female), which melted within a few minutes of ramping up the GPU. I think I was lucky that it didnt catch fire or damage the equipment (~£5000 server).
So I'm after 2 heavy duty LP4 splitter cables, OR I should be able to use 4 heavy duty LP4 extension cables.
Any ideas on where to get these?
Thanks,
Paul
If it's a 'real' server then I'd guess that the PSU is perfectly adequate, but it just doesn't have the necessary cabling. Powering video cards isn't usually the first concern with server power supplies.
I wouldnt trust running a 290 via molex connectors to be honest. If it doesnt have any 6 / 8 pin connectors, can you even be sure it has enough amps on the 12v for running a 290?
Are you intending to use this for mining?
