HEELLLPPPP!! NZXT PHANTOM 360 RADIATOR PROBLEMS!!
18 Oct 2012
Wales
Hi all,
My water cooling set up arrived yesterday and I spent all afternoon trying to install the radiator.
I planned to install it in the top of the case.
I can see there are 4 holes on the cross section.
What screws can I use to install it.
Does any one have a detailed installation guide?
Thanks for the help in advance.
Nick.
Hi, the screws will be either 6-32" or M4 depending on make. Be careful of the length you can use washers so you can add them, so you don't damage the rad if need be.
