Helicopter Landing Sounds
20 Jan 2008
A few weeks ago i built a new pc with a corsair 550d and a h100 for cooling
only using the stock fans that came with them, i have the cooler in pull only as there was a problem with the length of the screws but when its been on about a hour you cant hear yourself think its really loud, i thought the 550d was part of the silent corsair cases but you would have to be deaf to not hear this case. there are 2 fans bottom front, 1 back top and 2 in the roof on rad, i have set thermal radar on sabertooth z77 board to silent but this make no difference to anything, all fans are plugged into motherboard but top 2 and plugged into cpu cooler part of h100, can anybody give a bit of advice or recommend new fans
Thanks
The thread title had me puzzled :p
You could try using them with a fan controller?
I use one of THESE on my H50, and its very good! I know there is a comment on the product page saying that it is noisy, but for what performance, it is far from it compared to other fans of its type :)
Same as Ryan-3, I thought my PC would take off with my Corsair A70 fans, swapped both out with 1 of the fans Ryan suggested and near silence and better temps under load.
The problem with the A70 was the fans were not PWM (able to spin down slower when the computer is idle).
i will take your word for it bobo696, just ordered a pair for the h100, and they are on special
Order date and time: 27 Jun, 12, 4:53 pm.
Your order consisted of the following items:
Item Qty Price
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin 2 £22.96
Thanks again for the help everybody
just a update. on the fans.
you cant hear these running even at full speed i installed them in push. keeping pc very cool
in 550d case great buy.
